Hi Everybody,
I have a dryer not heating up. Everything seem to be fine except the dryer is blowing cold air. Could it be the dryer heating element? or something else? Any help is appropriated.
Thanks,
Hi Everybody,
Thanks,
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LEC7858AN0
See the attachment for the wiring diagram.
Yes it could. Visually inspect it or better yet measure it with a meter, should be around 10 ohms.
or something else?
Also yes. Could be a power problem the motor, timer etc all run off of half the line (120 volts) but the heater requires 240 volts.
Also could be any device in the heating coil circuit. Check the thermostats with a meter all should be 0 ohms (closed).
If the thermal cut-off thermostat is blown get back to us as there are other things to check before replacing it.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Using the meter the heating element is around 6-7 ohms. Also, I check the thermal cut off for the upper thermstat which is o ohms, but the bottom thermal cut off is some ohms. Could it be the thermal cut off is blown?
I just replace my thermal cut-off for both and the dryer is working now. Thanks for your help. Appreciated your input.
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
