I have test all the fuses, all test good. Change the timer and still no heat.
Have you checked the heating element? If that is broken, it will need to be replaced.
A model number would be useful.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Start by checking the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
