Whirlpool Dryer not heating
Dryer stopped heating. Drum turns, fuses all ok. I replaced the heating element and the thermostat and still no heat??? What gives?
I cannot find any info on the given model number, please check it.
I would check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heating element requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
