Dryer not heating
It still turns the cylinder but isn’t heating. Is it difficule to change the heating element and if not, how do I do it?
A model number may help others help you.
Before opening up the unit check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The heating element requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
