Dryer comes on Perfect for approximately four minutes then it sounds like gas gas shuts off indeed no heat. Heat wont come back until I leave shut off 5-10 minutes then it just same ole thing. I have noticed a periodic glow must be an ignitor when i try to increase time on dial after heat shuts off doesn’t work , only way it will restart is shut off and come back after again 5-10 minutes. I have checked vent ducting not the problem i also replaced the thermafuse and the thermastat. But now i think i getting closer to believing its somthing to do with gas because today i actually smelled gas outside where dryer vents. Questions thoughts ideas???
Related topics
whirlpool Gas Dryer | 2 | 893 | July 9, 2009 | |
Gas dryer heats up but goes cold in minutes | 2 | 5090 | June 3, 2012 | |
Dryer stops heating after 5-10 minutes | 3 | 3386 | August 19, 2012 | |
Dryer heats sometimes but not all times | 3 | 3319 | September 26, 2017 | |
Dryer heats for couple min-then no heat | 2 | 2102 | September 25, 2012 |
