My Dryer Stopped Heating…i Took The Heating Element To The Parts Store…he Said The Heating Element Is Still Good And That I Needed A Thermostat Switch…i Replaced That And Its Still Not Heating…what Could It Be?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LDE4914ACE
Here is a manual. Although it does not show your specific model number it looks like a LDE4914 on Page 5-1 is a close match.
http://appliancedigest.com/index.php?/files/file/472-16008714-1994-1997-maytag-dryers-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Then the hi-limit thermostat. It should be 0 ohms.
Then the timer contacts (# and 4)
And then the motor centrifugal switch that provides power to the heater.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
