Dryer not heating
Our Kenmore 80 series gas dryer is not heating. The drum turns fine, and I have made sure lint ducts are clear. Looking through hole in front, I see the unit glow and then light. After a couple of minutes, the fire goes out without reigniting. The unit will periodically glow again, but will not ignite.
Common problem that I see often. There are two coils on the gas valve that are at fault and need to be replaced.
279834
Thanks so much for the solution! I replaced the two coils and the dryer works perfectly! Thanks again.
Awesome, thanks for the update.
