I’ve had this Frigidaire combo(washer/dryer) for almost 3 years. It came with the house I bought. It didn’t work when I first got it so I changed the motor and nothing. I let it sit for about 2 years then I thought I’ll try to fix it. I put a new push start switch and timer in it and it ran great for about a month. It started making rattling sound. It was the drum moving. So I put on a new rear bearing and it was still rattling, but would only start if I pushed on the inside. I just replaced the felt on the dryer and it came on for less than a second. I change the motor back to the original one and still didn’t do anything. I checked the thermal limiter and got either .001 Ohms out of it. I also checked high limit thermostat and got something around .500 Ohms. I had the multimeter set on 2000 Ohm setting.
What should I look for now? Washer still works fine.
