I have a Kenmore stackable washer/dryer and my dryer won’t start. When I turn and hold the start switch I can hear the timer make a noise but the dryer won’t start. Do I need a new switch or a new timer?
Here are the parts. Your unit is actually a Frigidaire.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=41797802792
Here is a manual
http://frigidaireservicetips.com/pdfs/488_3.pdf
I am guessing that this will be close to your unit but cannot confirm this.
If nothing else it will give you an idea of how Frigidaire does things.
Probably neither.
If you look at Page 14 in the manual you will see that there is a Thermal Limiter (fuse) in the motor circuit. I would check this, it should be 0 ohms at room temperature.
If it is blown be sure to check/clean your vent system. This is the most common cause of it blowing.
Also clean/check the blower wheel.
— Begin quote from rockylowe;173037
Thanks,
The repair manual was a big help. I’ll check it out,
thanks again.
I installed the part and the dryer works fine
Thanks for everything
Rocky
