Dryer won't start
This is a "stackable" unit; dryer will not start. Replaced the start switch and timer and it still will not start. Anything else I could be missing? I don’t have the wiring diagram…
Hi.
Check the thermal limiter (fuse)36 on the diagram#2 most likely it’s open. Clean the air ducts inside and outside the dryer.
The limiter [part]134120900[/part]
Here are the breakdown diagrams and Replacement parts for Frigidaire FLEB43RGS1 LAUNDRY CENTER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
I’ll try that and I will post the results. Thanks very much.
You are welcome.
Simon.
— Begin quote from Simon / APP Team;737800
You are welcome.
Simon.
Quick question? What’s the easiest way to access/change the limiter? Remove back panel or can I access it by removing the top panel? Got the part and I’m going to replace it (try) today.
Hi.
You should be able to get to it from the top.
Simon.
