I have a Whirlpool Duet Dryer. My wife was using it the other morning when it just up and stopped running. I have taken it apart and checked all connections, nothing lose. I have run a diagnostic and I’m showing no error codes. The control panel appears to be working properly. However when you press the start button you hear a click the sensor light lights up and the dryer does not start its cycle. I am at my whits end? Please help!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GEW9250PW0
See the attachment for the tech sheet which you probably already have as you said that you had run the diagnostics but I just want to be sure that you have this info.
I would check the thermal fuse and the belt switch.
— Begin quote from denman;370306
Replacement parts for WHIRLPOOL GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.com
(Tsailor) Thank you so very much for your response. I sure will try both those suggestions.
Thank You.
I am having the same problem. what did you do?
