powers on wont start
Our front load dryer will power on put won’t start in any of the selected cycles, makes the beep sound as usual and makes a single click sound like a relay, sound comes from circut board area rear upper right of unit, door switch checks out fine. sensing light comes on with sound of click, any help would be appreciated. Thanks Robert
http://www.appliancepartspros.com/parts-for-whirlpool-gew9250pw0.html
See the attachment for your tech sheet
Check the thermal fuse (item 59 in the Bulkhead Parts section). Should be 0 ohms.
If blown be sure to check/clean your vent system as this is the most common cause of it blowing.
Would also be a good idea to check the thermistor (item 42 in the Bulkhead Parts section) resistance.
Check the belt switch.
— Begin quote from denman;815855
Parts for Whirlpool GEW9250PW0 Dryer - AppliancePartsPros.com
Found blown thermal fuse, hope thats all. Thanks for the help, Robert
