Dryer works but don’t heat. I was told it was the thermostat. How would I replace it myself?
— Begin quote from telena;271897
Telena,
There are two thermostats and two thermal fuses in you heat circuit, besides, other components.
Being that this is an electric dryer, the most likely situation is a broken heat element(more common than a thermostat or thermal fuse).
You will need to dismantle the machine to access most of the components, and you need a meter to test circuits and components.
Let us know when you have the tools and meter and we can walk you through it, and get it fixxed.
