Dryer Screech
Whenever the dryer is turned on, a God awful screech, kinda high pitched noise is made, is it belt or bearing. Doesn’t really sound like a belt. Thanks:confused:
— Begin quote from mauimark;394123
Mauimark,
Your noise is most likely the rear bearing assembly,
[part]AP2142648[/part]
Or something stuck in, or worn out drum glides,
[part]AP2107932[/part]
Heres a PDF file to assist you in accessing the components
http://www.frigidaireservicetips.com/pdfs/488_3.pdf
Good Luck,
