My GE dryer has a squeek .It is not a steady squeek.It does it more when you first load it with wet clothes when it is heavy .As the clothes dry the and the load gets lighter the noise slowes down. Anyone have any ideas. It is driving me nuts.
Harry;)
The rear bearing parts on these go bad all the time. Take out the drum and replace the parts you see on this exploded parts diagram.
— Begin quote from sidfink43;298525
Drum replacement parts for General Electric DDE0590GBM Electric dryer | AppliancePartsPros.com
Sidfink43
I see a whole Dryer diagram .What part NO> do i use
Harry
This kit should be what you need. When you open it up you may see more parts that need replacing.
