I have a maytag dryer I have owned for nearly 20 years the thing has stopped makeing heat. The motor runs and the fan blows but no heat. I have taken it appart and the heater assembly appears to be fine there are no breaks in the heating element. The fuse tests as Ok with an Ohm meter and thermal switch shows no readings at all with an Ohm meter. Does any one have any ideas as to what might be wrong? Thanks G
Related topics
Dryer wont heat | 2 | 688 | August 16, 2015 | |
dryier not heating | 1 | 1161 | January 30, 2014 | |
Maytag Dryer *usually* won't heat | 1 | 168 | June 12, 2020 | |
Dryer stopped heating, everything else working. | 1 | 832 | February 9, 2016 | |
Dryer won't Heat | 1 | 1603 | November 28, 2009 |
