Dryer won't Heat
I have a Maytag LSE7804ACE Washer/Dryer Stackable Unit. I was told to order a new heating element. When I installed it still no heat. I checked the voltage at coil its reading 120Volts. I checked the thermal fuses there closed. I checked the thermostats they are closed. I am getting 240Volts on the Back of the unit can you help?
