Hi there. Thank you for all the help that you provide. I need some help. My Whirlpool dryer is no longer Heating up, everything else works fine. The hi-limit thermostat is open so I need a new one. The part # is 3399848. Could you tell me where I find this part on your website? Second question is what else should I check?
Hi temp thermostat (3399848)is open
Thermal fuse (3399693 … Is this the correct part?) seems fine
Cycling thermostat I couldn’t find.
The hi-limit thermostat is shown as #15 on the diagram. It comes as a part of the kit including the thermal cut-off thermostat (#6). The cycling thermostat is shown as #24 on the same diagram.
Thank you Gene. I bought those parts and also some parts I needed for my refrigerator. My issue is fixed. Thank you so much for your help. Your service is amazing and shipping is lighting fast!
