Dryer will not heat…I just replaced the ignitor and it glows and i hear a clik,but no flame…maybe need new coils or Flame sencer???
— Begin quote from Frank33;300146
Frank,
When you hear the second click, does the igniter cycle off and start to dim ?
If so, your Sensor is ok,
If your sure you have gas supplied at the gas valve, you’ll need a set of coils for the gas valve
[part]AP3094251[/part]
Good Luck,
Hi Joe-
I only hear one click and the ignitor dims.After about a minute it lights up agian I Hear one click and it dims agian…
— Begin quote from Frank33;300248
Hi Joe-
Frank,
And you’re sure you have gas supplied at the valve.
Order and replace the gas valve solenoids(per the previous post).
You’ll be fine after that…
Yes gas it supplied to the dryer!!
Thanks for all your help Joe!!
— Begin quote from Frank33;300512
You’re welcome !
Let us know how you made out, when you’ve got it repaired.
Good Luck,
IT WORKED,IT WORKED!!!
Thanks again JOE!!!
— Begin quote from Frank33;301951
Thanks again JOE!!!
Frank,
Of course it worked,
You did a great job.
I suspect you are correct.
First wife notice washer not draining periodically. Did not happen to me for sometime but when it did happen, I could not get it drain and/or spin. I also notice the timer remained on turning until I turned it off. Now I am not sure if it is a drain pump or timer issue. What can I do to find out which part is the problem? I do have a digital ohm meter.:rolleyes:
Washer must be drained before it will go into spin. After agitation stops and it won’t drain (timer continues advancing), check for 120vac across the pump terminals. If good, pump is faulty unless it’s running but not pumping (may be blockage), if not, timer is faulty.
http://www.appliancepartspros.com/ge-pump-and-motor-wh23x10013-ap3160348.html
GE WH12X10202 Timer - AppliancePartsPros.com
Eric
Great! What I have done was attached leads of digital reader to drain pump connectors plug in unit, turned timer to drain cycle and pulled to start the timer to supply power to drain pump. The digital meter reading was near 120vac. Thus timer is supplying power to drain pump. The pump is not clogged though removed drain pump "propeller" and notice collar (plastic) at base of spindle where it slides into housing and meets enclosed motor broken. Also small particles what appears to be sand on outside of drain pump housing. From all of this I gather that the pump is faulty not the timer. All that said, I removed broken collar plugged in drain pump turned on power supply to drain cycle and pumps works but rattles. I believe that the issue maybe the broken collar which is a very small part. Who will have it?
After further thought…I will purchase a new pump from appliancepartspro webb site. Thank you for the forum.
