Tim
Hello Ya’ll, my dryer won’t heat up. The ignitor comes on for about 5 seconds then goes out. I order, from you guys, and replaced the gas valve coils, no help. I check the Igintor it is less then 100 ohms. I also check the flame sensor and it has continutiy. Not sure where to go from here, any help at all. Thanks…
— Begin quote from timmyd4;303922
Timmy,
You are sure you have gas to the gas valve ?
You may want to remove the valve, remove the burner orifice, and check for a clog(spider web) inside the orifice and valve body.
If those all check OK,
I would have to think, you’ve got a mechanical failure inside the gas valve.
[part]AP3094298[/part]
Good Luck,
:cool: :cool: :cool:
