i have a dryer that does not heat up have checked igniter and flame sensor both check out whats next?
— Begin quote from filthmaster;317620
Filthmaster,
Apparently this is a gas dryer,
Does the igniter glow and does it cycle off with no flame ?
(if so, suspect you have a bad set of gas valve coils).
If nothing occurs, you’ll need to circuit check all your thermostats, they all should be a "closed" circuit at room temperature.
Also check for any loose or broken wires.
We could be more accurate with a model and serial number for the dryer.
