I have a Kennmore gas dryer model # 110.73022100, I did not want to post such a common post but I has tried every thing I have read on this forum so far. I am out of options without your help then it’s a call to the repair man.I started off checking the air flow, the ducts were clean and unrestricted then, I figured out my thermal fuse was bad so I replaced the fuse and now my ignitor comes on for about a minute to a minute and a half. My dryer still will not heat up so I check my flame sensor for Continuity flame sensor is good I also replaced both coils thinking they could be bad. The ignitor,flame sensor,coils, " other sensor on yop of the flame duct all get 120v. I still no flame or gas any ideas? P.S. Gas valve is on and gas is comming to gas valve in the dryer.
Brendan
