Dryer will not Shut off
I replaced the timer on my maytag dryer and it still will not shut off on timed dry or electronic dry. I can advance the timer to off and it will not shut off
Hi.
Check if the start/control switch actuator is connected to the solenoid. If it’s not the dryer wont stop.
Here are the breakdown diagram and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=28155&diagram_id=28443263
Thank you.
Simon.
