My dryer worked one day ago. We have not had any problems to this point. As of today when I push the start button I get nothing? I checked the circut breaker and it is on. I did switch it on and off. But nothing.
Here are your parts with wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PYE3300
The only sure way to check for power is a meter.
A likely cause is that the thermal fuse has blown, Item 5 in Section 4.
You will note that it comes with a hi-limit thermostat.
Th hi-limit should have regulated the temperature so that the fuse did not blow. Therefore it is assumed that the hi-limit did not open and also needs replacing. In any case you have to find out what caused the unit to overheat.
If you noticed that the unit was always running hot it could be that the cycling thermostat on the blower assembly is shot (contacts welded together).
Another common cause is a grounded element. The element has sagged or broken and is touching the case. Then it always runs on high and the thermostats cannot control it. Often you can see this by inspecting the heater assembly.
The best way to check is with a meter!!!
Check the power at the plug
L1 to L2 should be 240 volts
If OK check that all the wires at the unit’s terminal block are OK
If OK it is not a bad idea to check the power at the terminal strip just to eliminate a bad line cord as the cause.
If OK
Unplug the unit.
Remove a wire from one side of the thermal fuse and check it, should be 0 ohms.
If blown
Remove both wires going to the heating element and measure it, should be about 12 ohms.
Then measure from each heater connector to the case/frame, both should be infinite ohms (open). If not you have a grounded element.
Also a good idea to clean/check the blower wheel and the vent system.
