Dryer will not start
I have a maytag MDE 9700 AYW, and the dryer will not start. I have power, and it will try to start then flash an upside down F followed by a 5. I followed the instructions someone posted about reading the codes and it shows an eror code of 1 with the locked button lit up next to it. I cleared the codes and the dryer will start and run for 30 seconds then stop and flash F5.
I took out the Thermistor, and it was soaked as well as the vent. I checked the ohms on the two posts and my craftsman auto range read 13.4. What do I need to do now? It still will not start unless I clear the codes.
clock/timer/oven display lights up,when you turn any of the burners on(smooth top range)a small indicator lite comes on that burner is on however none of the burners will heat up plus neither the oven or broiler will heat NOTE:my son just purchased home and range came with it so we dont know history of range. Any help as to whats wrong greatly appreciated.
You folks are great. I removed back and went to terminal block as you suggested. Found 2 loose wires and 1 disconnected,made repair and now everything on range works great. Many thanks; Gary
