Dryer will not start
Whirlpool electric dryer will not start. I have proper voltage. Start switch clicks in and timer runs. I have checked door switch and thermal fuse. I have 120 volts at the motor plug from the blue wire to ground but not from the blue wire to the white wire. Motor windings seem o.k. I am beginning to suspect timer. Need instructions for checking timer, or other part to look for.
Make sure the door switch is good. You have to have continuity
between white and white/blue wires with door closed. If the
switch is OK replace the timer.
Door switch AP3132865
The timer AP2947449.
Here is breakdown diagram for you dryer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=262851
