Dryer wires burned
I just replaced the heating element about 4 months ago. It has been working great. The dryer only works on airfluff. If it is on any heating setting it shuts off after 2-3 minutes. Both wires coming out of the heating element are completely burned up. The heating element is fine, the multimeter has a reading of 12.1. So the wire from the heating element to the thermostat is burned and the wire from the motor to the heating element is burned. Both of the wires that hook to the heating element are burned (where it would connect to the heating element).
