First time posting.
My daughter has a Kemnore Elite Dryer that does not heat. The high temp cut-off switch keeps blowing. We have done the following; cleaned the entire exaust system, shortened the output hose to the outside to about 9 inches,replaced the heating element, replaced the thermal cut-off switch and thermostat(twice), and performed the troubleshoot tests that came with the dryer. Tests were ok. The dryer worked with a damp towel but when we put a small load of towels in, the cut-off switch blew again causing the heat to stop while the drum continued to operate. We have spent too much time and money on this problem. I am hoping that someone can lead us in the right direction and help us solve this problem.
Thank you in advance.
