Dryer won't heat
the timer seems to work in all positions, but i get no heat, checked the heating coil and it’s fine. What’s up.:confused:
It could very well be the thermal fuse, which is #9 in the bulkhead picture of your breakdown. I also would check the breaker. It could be partially tripped. Just because the dryer runs, that does not mean that it has full power. Kick the dryer breaker off and on a few times, and then check the dryer and see if it heats. Tom http://www.applianceeducator.com
