I assumed I need a heating element, or is there something else that could be causing my electric dryer not to heat. Its spinning fine.
— Begin quote from swtpotato3;398097
Swtpotato,
Have you checked and reset both breakers at the breaker panel ?
or ch
Try that first, then consider a heater element.
There are other components to consider, but the heater element is one of the more common problems.
