Dryer won't run
:confused: The dryer won’t run when the start button is pressed. Later, we had it in the off position and the 30 minute wrinkle cycle was set to on. Suddenly, it began to run. So, we can get it to run in the wrinkle cycle, but not in the timed cycle or automatic cycle with heat.
Is this a timer issue, or are there other components that could be causing this problem?
Thanks!
