When I set the timer to any mode (regular, permanent press), the dryer makes small clicking sounds but when I push the "Start" button the dryer does not run at all. When I move the timer dial to the "finish guard" cycle, the motor and the drum run fine - most likely this cycle doesn’t need any heat. The door switch is fine.
Could this be a timer switch issue or the thermal fuse issue? Appreciate any pointers.
-kd
