I was using my dryer the other day and it just quit in the middle of a cycle. No buzzing noises nothing when I turn the Timer on. I checked the voltage going into the dryer, the breaker, the start switch, door switch, Thermal Fuse, Thermostat,Timer Motor and the Motor. They read fine. My brother in law suggested the replace the Dryness Control Board. I can’t find any information if this would cause it not to start at all. Could this be a possibility or is there something else I have not checked that I should have?
Thank you
