Dryer Won't Start, Checked Everything
Hey guys, I have been fixing appliances for about 6 months with a friend of mine, and we have never run into this problem until now. I was given a broken dryer, and the guy said it didn’t turn on. I checked all of the fuses, the belt, and the motor, and everything was good. Usually a bad motor has a buzzing noise, this did not. The thermal fuse, thermostat, and all of the fuses have continuity. The only thing I have read online that it could be is the timer, but I am not sure how to check the timer. Any help is appreciated and if you really need the model number I can get it. Thanks
Yes, can’t help without the model number.
Eric
