Maytag Neptune dryper won’t stay powered up after the power switch is pushed. It will however stay on after several times. Sounds like a relay in the left side of machine won’t stay energized. Get’s Error code PF, if you push the switch only once. What is the problem and what parts do I need to fix it.
Thanks,
Karl B Frederick
