dryer wony heat
i just replaced the heating element and still no heat.i was looking at thanging the saftey thermostat do you think this could be the problem??
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=dvl223eb4ww
I would check the thermal limiter, Item 1236 in Section 1, then the safety thermostat 1236 in Section 1.
Both should be 0 ohms. If the fuse is blown I would replace both.
If the fuse is gone.
Clean and check the blower wheel and the vent system.
Make sure the lint filter is not coated with fabric softener residue.
Check that the drum seals, 1220, 1221 & 1271 in Section 3 are OK
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
