dryer was not heating, I inspected it and found the heater coil was broken and ordered one. Received it and installed it and it still has no heat.
Do you know what else could be the problem?:mad:
If you have an ohm meter check the thermostats for continuity (with the wires off each one) that will tell you if one of those are out.
you might also want to throw the breaker off and then back on, sometimes they partially trip and look on and they really aren’t.
Nat
