Dryer
:)Hi
I have a dryer that will not blow any air hot or cold . the drum turns timer works can you help me find the right part to replace.
Remove the rear panel and the lint chute (#1 on the diagram). Check the blower wheel and make sure the chute is clean.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246728
