on the display panel none of the buttons or the display light work the only light that is let is the light that says control locked. light inside the dryer works. I have checked the circuit to make sure non of the breakers were off, dryer still not working door shuts all the way.
— Begin quote from porternat;258290
Sounds like someone locked the control panel(child lockout option).
Press and hold the signal on / off button for 3 seconds.
That should unlock the control panel.
You may need to check that in your user’s manual.
— Begin quote from Joe / APP Team;258307
You are wonderful, what would we do without you! thank you so much, problem solved.
— Begin quote from porternat;258372
You are very welcome,
We’re glad, you’re up and running.
