No Panel control
My dryer won’t start. The keypad control panel lights up and the last user settings are there. I cannot change any of the user settings and when I push the start button, it will not start. When I push the stop or off button…nothing happens. Control panel still remains lit. I unplugged the dryer and patiently waited 30 min. I plugged it back in and nothing. I replaced the controller board. Keypad lit up, settings were what I had changed them to, but dryer would not start or turn off at key pad. The vent is clear and the dryer door latches. Thanks for your help. out of ideas…other than could the moisture meter in the door be an issue??
Model MDG5500AWW[LEFT][COLOR=#000000]
I have seen this posted several times on this form but no one ever answered the question…how can you fix this? Can you please help…this is for a neighbor that has limited mobility…
thanks
[/COLOR][/LEFT]
