Maytag don,t turn on
Dryer repair [RIGHT]Model Number: MDG5500AWW Brand: Maytag Age: 5 - 10 years [/RIGHT]
I have a MDG5500AWW Maytag gas dryer that will not start. I can’t even turn off the display. It seems that the start, stop, and buzzer + bottons don’t work. All other bottons do something exept start, stop, and buzzer + bottons. When I push the start botton, nothing happens. Not even trying to do anything. My serial number is 56780541AX. Is there any check I can do before forking over $150+ on a chance it is the key pad?
Read more: http://forum.appliancepartspros.com/dryer-repair/93782-dryer-repair.html#ixzz1G2UExQNP
Most likely the problem is a bad key pad which is a part of the console assembly.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47838
