MAytag gas dryer won't start
I have a Maytag MDG6700AWW propane dryer. All the lights indicate the dryer is on but when I push the start button the dryer does not start. I had a service tech come to my home and he said the "control board" was bad and it will cost over $500 to repair so I should just get a new one. I ordered a control board and it did not repair the dryer. I also tried the board behind the control buttons and that did not repair the dryer. Do you have any other ideas?
Hi.
Did you check if the belt or the belt switch is not broken?
Here is the breakdown diagrams and Replacement parts for Maytag MDG6700AWW DRYER- GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
