washer does not spin clothes dry enough and rattles
Lift up the washer from the front and check the belt.
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1345715&&model_id=5174299
Thank you.
Can you please go step by step how to replace the belt. It was very loose and I need a new one. Thanks again
Place the belt onto the motor pulley and the pump pulley. Loop the belt over the transmission pulley and rotate it into position.
- The part number for the belt is AP248258
You are welcome. Keep us posted.
Dryer will not start,does it have a fuse and where would I find it.
You will need a multi meter to do some checking.
First make sure you have 120v coming to each side of the connection block. Then unplug the machine and look inside the door frame. At the top should be some screws which hold the top to the cabinet. Take them out and take off the top. You can now take off the front which is held by two screws, unhook the door switch wires (make sure you label them so you can put them back correctly) and take off the front. You can now remove the drum, inspect the heating coil and you will see fuse and themostats which can be test for continuity with your meter.
Good luck
