duet washer error code - f ( electr. prob.)
got error message - electrical problem - cycle stoped at rinse and spin - reset and tried several different cycles from the beginning . now get same code and cycle stops and low humm. checking with others on same problems seen before i unstack and dig in.
not electrical! pulled lower front panel. unscrewed pump filter and cleaned filter. looked in cavity and tada! a sock worked its way into the drain tube.
