Whirlpool Duet Washer F 02 code
I have a Whirlpool Duet washer that is failing with an F 02 error code. I’ve checked for clogs in the pump filter, the hoses and under the drum. I also replaced the pump, but I’m still getting the error. It doesn’t appear to be a drain or pump issue as suggested by the error code because I’ve seen water successfully drain. However, the drum is not spinning. Could it be an issue with the motor?
Thanks!
