Duet whirlpool washer is leaking water from under the soap dispenser, as soon as the washer starts filling . Need help, is it something that can be fixed easily, or do I need to call for repair. Please help.
This could be a cracked soap dispenser basin, but more likely a cracked water line. When the machine fills the water is diverted through the soap dispenser to the basket.
This is some you can fix, start back taking off the top and see if you can determine the problem.
