Washer leaks only when it’s filling. Its seems to be leaking just under the hose that goes from the soap dispenser to the drum. Then the water travels in back of the lower counter weight and then onto the floor. I’ve taken the top off the washer and check to see if the hose is leaking but it seems to be ok. I’ve also looked over the main door gasket and it too looks ok. Is there something else under the soap dispenser that might be leaking?
I can only suggest you pull out the dispenser and see if you can find the problem. It may be in the line coming into the dispenser.
Leaks like this are just darned difficult to find, you just have to keep at it.
Here is a service manual that will show you how to remove the unit.
