During spin washer leaks water from underneath…
You need to open it up and operate it with the front panel off to see where the leak is coming from. Here is a service manual that will help you do that.
http://www.servicematters.com/maytag_library/docs/16022937.pdf
This service tech will talk about the seal replacement that may be necessary.
http://www.servicematters.com/maytag_library/docs/TDL-0060-B.pdf
