E2 -F3- fault code displayed
I used the convection feature on my oven last night and after turning it off, the fan stayed on awhile, but I didn’t notice any error message. This morning my wife went to the kitchen and said it was still on. When I went down, I saw the E2 -F3- error displayed. My question is, is this the same as the F3 - E2 error code listed on the oven fault codes page? I’ve seen the fault code listed either way so I just need confirmation they are indeed the same thing. If these codes are the same, and the problem is with the heating sensor, please advise where I can find replacement parts, instructions and diagrams. I was able to clear the error by flipping the power to the circuit and when I tested the oven just using the baking cook method, it was fine. I haven’t tested the convection setting yet as I don’t want it to come back.
Thanks!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rbs307pvs02
The oven sensor is Item 28 in Section 01.
Clicking on it will bring up more info about the part.
Yes the errors are the same.
