When I turn on the oven in Bake mode, it heats up for a little while and then makes a funny noise and displays fault/error code E2 F3 and locks the door; when I hit Cancel it cools down a bit and then unlocks the door.
My husband and I checked the spec sheet for the code.
My husband then checked the oven sensor and it reads 1080 ohms at room temperature.
He then took off the control panel and proceeded to check all the leads with the ohmmeter to the spec sheet and they all seemed to come back ok, as well.
We are at a complete loss as to what is causing the problem and would be very grateful for any help!
Thank you for your time.
Hi.
Based on the info you provided the control board should be replaced
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-parts-for-whirlpool-rbs305pvs00.html
Post the results.
Simon.
